driver70
- 0
- Mar 8, 2005
West Bend,
Wisconsin
I just recently barely failed the WI emissions test doing the idle, 2500, idle sniffer test. It failed on HC at idle- limit 220 ppm, tested 224.2 ppm. I also failed because of my hacked air can which I need to replace with a stock one. When I took the test I had some old oil in there since I had a leak somewhere and have just been topping it off, and I had a dead whining turbo so I completely disabled it by disconnecting the wastegate actuator arm.
My question is this- I just finished installing an EVO III GT turbo, with a fresh oil change using Castrol Syntec 10W-40, and I'm going to use "Guaranteed to Pass" in my next gas tank... when I re-test should I disable my turbo again, or leave it hooked up and see what my test results are?
Rommel
Rommel
