Replacing 95 elcipse fog lights
smoov1011
Mar 31, 2005
grand rapids, Michigan
I feel stupid asking this, but how on earth do you replace the fog lights on a 95 eclipse??
there should be a screw or two down by them, remove both of them and disconnect the wire harness and it should pop right out, i had a 95 talon and that was how i took mine off, should be the same for the eclipse
yeh there shouldnt be anything blocking those screws, there is one plug on the back/side of the fog lamp that pops out easily but thats about it, and one electrical plug in the back just make sure not to break anything when u r yanking on stuff :dsm:
I see two screws on one side, got them out. the light housing is still being held on some how on the other side. I see a screw but turning it seems to be fruitless as what ever it's threaded into spins with it... I can almost swing the housing far enough out to get at the plugs but I don't want to break anything.
