dsm4bk
- 68
- Nov 25, 2002
I bought a '95 TSI AWD in April that had crankwalk. The crank eventually knocked the CAS out and ruined the engine. I just had a '97 engine swapped in. one thing I should point out, is that he also installed a supra sidemount which involves beating in part of the car to get it to fit. As soon as I drove the car after the swap I noticed the steering felt very odd/different (I had 3 turbo 2G's before buying this car, so I know how the steering should feel for this car) The power steering seems to work, but when I turned the car, the wheel would continue to turn in that exact direction. I have to turn the wheel back straight manually to go straight again. I told the guy who swapped in the engine, and he said I'd just need an alignment to make it normal again.
I took it to get an alignment, and after it was done (and everything aligned to spec), I had the exact same problem. It also pulls very badly to either side if I let go of the wheel at highway speeds (mostly left) I returned the car to the shop that aligned it and when he took it for a test drive to see if it was true, he agreed that something didn't feel right, so he aligned it all over again, and it is still giving me the same problems.
The other odd thing about it, is when I go over bumps, the wheel kind of jerks to the left or right after the turn, really weird.
I have stock springs, tokiko 5 ways in the front, and kyb agx in the rear (agx are set to 1, and tokikos are set to the a little firmer than the softest setting) I have new rims, on 225/45/17 tires with good tread and still soft. They blanced out well.
I took the car to another mechanic to see how the power steering is working, and on the hoist he couldn't find anything wrong with it. He didn't notice anything wrong with the joints, shafts, etc,etc either. The passenger side wheel has a tiny bit of wobble (bearing) but it doesn't make any of the bad symptoms yet, or the whinning noises when driving.
Could the speed sensitive steering be bad, and how do you diagnose that? It feels very unusual, like the steering is dead (its almost too responsive when I turn the wheel on the highway, but again, it just stays at the same turn and I have to manually turn it back straigt)
I'd REALLY appreciate any suggestions or help on what to do.
