critchfield
- Dec 2, 2003
akron,
Ohio
heres the numbers for my talon awd tsi 155,155,135,145 is that bad???? let me know thanks
Compression leakage is as likely to be rings as valve seats. To rule out valve seats, you do a "wet" test, where you blip just a bit of oil into the cylinder so it can seal up the rings. If the compression number is still low, it's valve seats/faces.Originally posted by 91TalonTSiCT
low compression is usually worn rings, not worn valves.
