rookieupgrade1
- 505
- Dec 17, 2002
93 Ply Laser N/A
symptoms.....car shakes on take off unless I rev over 2000. Does this in reverse and first gear. Some shake when down shifting into 2nd. At take off the "shake" can be as bad af a slamming as if you poped the clutch and quickly pressed it again....repetadly. the clutch doesn't slip under high rev power......not even in 1st gear.
What I have done.
New clutch and pressure plate (throw out bearing)
new moter mounts
resurfaced the flywheel friction surface.
After puting in the new clutch, the problem went away for about 3 months. now it is back.
Anyoneave any clue??
What I have done.
new moter mounts
