So about a week ago I was driving And my check engine light came on. It was good old DSMLink telling me my car was overheating
It was about 3/4 the way up the gauge. So I pulled over at a gas station and let me car cool a little. I let my fan run to see if that would help. So I went to leave and my temp needle kept climbing. By the time I got to my friends the needle was pegged and had some smoke coming out from under the hood and overflow bottle spraying like crazy. The next morning I replaced my thermostat with an autozone failsafe one ( heard thats not the best choice) but its supposed to work even if it malfunctions so I thought ok insurance. Flushed out as much coolant that would come out. Filled back up with 50/50 and some water wetter and it seemed fine.
Now about a week later tonite I was driving home and noticed it sits on the little wavy line or a little above. I give up.
It flucuates though. On decel after speeding up it drops a little and upon accel it goes up a little. Fualty thermostat already?
I dont know when the water pump was last replace. I bought the car with 84k and it now has 104k on it. Could that be the problem or has the thermostat already gone bad. All mods are in my profile. I have a Mishimoto radiator a 12" electric fan and a 14" electric fan with the 12" pushing. The 14" is hooked up to a switch and the 12" comes on normally and I checked it is working
So any help would be greatly appreciated
Also I cannot see coolant leaking fro mthe head as I thought maybe my headgasket blew. I dont believe that is my problem bec coolant would leak all the time and its full and my radiator overflow bottle is also full. I thought originally my radiator had a leak so I used leak stop. I thought I got it all out but I didnt could that be causing my problem? I know I need to flush it again to get it out. Whats the proper way for draining it all? Also how about a low temp thermostat like Gates Racing 170 deg one?
