6bolt_tsi
- 42
- Jun 9, 2008
SLC,
Utah
What do you guys think? Well I have a top mounted GT42 w/ a bunch of other crap on my 1G talon and long story short, I got on the car and about 8500 rpms I hear a POP, sort of like detonation/timing. Well I baby the car home, which it seems to run just fine and I start pulling the spark plugs. The spark plug electrodes are dry and look the same, however the 0-ring/crush washers on all cylinders except for #4 are wet
crap. Well I do a compression test 1-3 cylinders and they are 150 (this is with Crower 280 cams) and cylinder #4 is 135
not good. Im thinking I lifted the head or the ARPs are loose right. After much shopping I find the correct tools I need. Eventually I start re-torquing the studs. Ya, there were a few studs that had about 1 to 1 ½ full turns. My question is, do you think it would be safe to drive the car again if the leak test when done, looks good? Im going to check and see if cylinder #4 compression is any better after re-torquing the head. This was on 34psi and race gas.
