Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 12-11-2007, 12:00 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 98EclipseTurbo is an unknown
2G-specific Oil leak at oil filter to ssline and noise in head.
Recently I have finished my new turboinstallation, and after it i noticed a large oil leak where the oil line L part connects to the filter housing. I have removed that fitting inspected the threads which look good on both parts. Then i put some RTV around the threads and after installing it all the way around for security. Started the car again and a smaller leak, so I put more RTV around where I missed. Did any one have this kind of a problem before ? , or knows on how to fix it ? I have not found a thread on this.
Second problem is that I found a noise in the top of the engine, loud scrapin noise.
The car has been down for a while and I put 5 quarts of oil after swap. It is not a rod bearing, and never heard it before beside the lifter tick. I read that the car need to idle for a little bit after being down and problem will go away, ?. I did take the valve cover before
off and installed a new gasked beside the turbo installation.
Thanks for help in advance.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bad oil leak near oil filter mount. steve_o1989 Newbie Forum 6 11-07-2006 02:17 AM
oil leak on oil filter housing??? 4BangerV8Killer Newbie Forum 2 03-15-2005 12:47 PM
Oil Leak Oil Filter Housing / Lower Timing Cover Prez Problem Diagnosis 4 03-01-2005 01:27 PM
coolant leak by oil filter?? xcelr8n Newbie Forum 5 12-16-2003 11:09 PM
Page generated in 0.09824991 seconds (63.18% PHP - 36.82% MySQL) with 10 queries
