djmixerx
- 325
- Oct 16, 2002
SF BaY Area!,
California
Ok Im very new to the 1g into 2g swap. This is my first one but i been working on 1g for a while now. I can setup timing on a 1g with no problems.
When I put the timing light on the crank pulley it reads under 10-15 BTDC. On a stock 1g timing is 5 BTDC I know that. Ive left my CAS fully retarded right now and its 10-15 BTDC. My motor is a 1g full swap head & block 1g timing cover. There shouldnt be any difference doing timing right. I put the timing light wire on cylinder 4 sinces its that new cylinder 1 right? Actually I did it both ways both are at the same place.
