Throttle Problems??
King_Milo
267
Nov 29, 2006
Hattiesburg, Mississippi
Lately my car has not wanted to start and when it did it would die soon after, I have checked everything, boost leaks, ecu, replaced the plugs, and today I played with the adjusting screw on the throttle body ( dont know what its called ) and it started right up without any problems, it idled fine around 750rpm but when i pressed the gas there is like a half second delay before it revs up any and after driving for a while it begins to act like it did before and just die, I feel like ive narrowed down the problem to this area of the car but what could be wrong with it and what should I do or replace??
well the ISC fiav and tps are all right there read about them and then go though the process of elimination. goodluck
