O2 sensor
reNgrOets19
59
Sep 11, 2005
sherrill, New York
Hey guys i was just wondering if a bad o2 sensor would make ## car hard to start and have like no power and run like shit......someone told me i had a bad o2 sensor i was getting horrible gas mileage and i went out to start it today and it just cranked for like 2 minutes then fired i hit the gas and it stalled.....thanks guys
Absolutely. A bad O2 will put the ECU into what's referred to as "li,p mode" where it will run poorly and make next to no power. Most of this is due to the fact that when O2 sensors go bad, they read lean and dump tons of fuel to compensate. This is often accompanied by blackened plugs, hesitation, part thottle misfire, poor mileage etc. There are other things that can cause these symptoms, but replacing the O2 is a great place to start. If you have an A/F gauge and the O2 doesn't cycle at idle or cruise, it's toast.
Don't bother with a dealer replacement either and I don't particularly care for the Bosch units. If you vist http://www.sparkplugs.com and reference your make and model, you can buy a Denso OEM sensor that was made for the car and requires no splicing on the connector. I have one of these and it also has the benefit of being more resistant to the use of leaded race gas.
Hope that helps,
Andy
Alright guys i put a new o2 sensor in and i still have no power and my check engine light still comes on any other ideas??
Yea i actually just left there and they told me that they didnt have the hookup or some shit so im gonna take it to a local shop and get it put on the computer.............
Is that right that u cant hook thease up to the machine?...if thats the case then how do i tell whats wrong with my car??......it runs like shit it stalls and has seriously no power at all it is boosting normal just no power....thanks guys
