bjoseph04
- 74
- Mar 27, 2006
Bradford,
Pennsylvania
Okay first problem is my starter.. I have a 95 eclipse gsx and was wondering to install the starter does it require taking off the intake manifold? or can you do it without all that hassle. Also can I just buy a used starter off ebay or something to fix it? There rather cheap..
Second problem is I just ordered a downpipe that's 3" will it bolt up to the stock o2 sensor housing or do I need a specific housing for it?
Third problem.. I know there's an o2 sensor up on the o2 sensor housing is there another one somewhere by the cat converter? What if I'm running a straight through pipe and not using a cat converter? Do I need to buy one of the cat back exhausts with a bung on it? Help? newb extreme..
