Help No Boost!
AWD 4G63
Sep 7, 2005
Hempstead, New York
I'm having a boost problem, When I drive the car, the turbo spools up fine. Sounds healthy. But when I punch it, it will gradautly creep to 7pounds and after a while make its way up to 12 pounds.... I don't feel that it boosts as strong as is could. Its a 91 AWD TSi.
Is there any common places where these vehicle suffer from boost leak. I was told to start by changing the intercooler and work my way from there. I need advice from you guys, where should I start at? Thanks Guys! :talon:
Any place that has a coupler. and also check the PVC valve and TB....
