knocking problem
ophlimitz
Jan 20, 2005
Lees Summit, Missouri
did a small rebuild. still leaking a little bit of oil from the oil pump, im pretty sure. regardless, started and ran fine for a couple days, cept for a piss poor acceleration problem, found my plugs were gapped at 32, so i regapped those. but at the same time the engine developed a knock and i know for sure its not the timing. i double checked that. took the valve cover off (which cracked somehow, i think from shot screw holes) and checked the valve train which looks ok but i could be missing something.
anyway. any ideas on why its knocking?
took apart and cleaned all head parts but didnt replace any. re honed cylanders and put in new rings. replaced most gaskets include head gasket.
