is it boost problems?
rated x
140
2
Jul 13, 2005
yorktown, Virginia
hello people 1st timer so bear w/ me.ok, i have a 97 eclipse gsx w/ a 92 6 bolt conversion in it.now my problem is that when i start getting boost (about 1-2psi),my car starts hesitating and sputtering.my a/f also fluctuates back and forth really fast.can anybody help?thank you.
You've either got a boost leak or a bad turbo.
Make a boost leak tester and check it out.
ok ,now how can i make one and how will i know its not an internal leak?i know the turbo is good i just replaced the turbine housing yesterday.it was still doing that before i installed it ,by the way. :D
i heard when you're doing a boost leak check that you need to cap off your boost controller intake hose.is this true?and which one is it? :confused:
i got fed up with this $#*% and took it to tuners edge.ill let them try to figure it out.ill let ya'll know the outcome.ttys, oh n thanks for the help guys. :thumb: :dsm:
well ,i came to find out that the fuel pump that was in the tank was faulty :coy: .i guess the idiot that had the car b4 me had put a fuel pump to a supra in it with out the filter.well u could guess the rest. :toobad: well thanx 4 everything. :dsm: :thumb:
weird i have the same issue...when i floor it it builds up to 1-2 psi then the boost jus stays there then gradually graises then i hit full boost (10psi) at 4500rpm on a 14b.....errrrr turbo spools fast in 3rd-5th but in 1st-2nd it takes me up to like 4500-5000 to hit full boost which isn't even the stock boost...
