TheBoosted96GST
- 107
- Jun 16, 2002
Avondale,
Arizona
well I posted a thread about a week ago the problem I was having was the car wouldn't start right away, if I came home from a good drive and turned it off then wanted to start it, the car would crank crank crank over, I kinda would have to pump the gas... and yes I know not what should happen with a fuel injected car, so anyway i'm pretty possitive that its the fuel pressure regulator, I noticed that if I leave the key in the acc. or on position the car will not start, even if it does have time to sit... could this be due to a fuse or relay? I don't know if this happens all the time but just a while ago when I turned the car off and pulled the key out I heard something flicker by the interior fuse box...btw cars a 96 GST 6-bolt 1G head, so what do you guys think it could be?
