freak4jesus_bt
- 109
- Jun 1, 2004
seligman,
Missouri
Well, here's the question. I put new gaskets on my engine last week, and new belts (timing, balance shaft). When the timing marks on the bottom were lined up, the dowel pins on the camshafts were both pointing straight down, which both my Haynes and Chilton manuals say that they are 180 degrees off.
Is this true? My car seems to idle and run fine. I thought about turning them to what the book said, but it runs fine now, and I didn't want any bent valves on my car. What should I do, and how would I know if my car timing is off??? thanks for the help.
