Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 10-28-2004, 03:05 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: POlarSource is an unknown
Car overheating - But no water leaks
1995 GSX with 6 bolt swap.
The car is fine running around town but when I stay at a constant 3k RPM's the check engine light comes on. The DSM link says it is a Knock Sensor Malfunction. About a minute later the heat starts rising and eventually I have to pull over, wait for it to cool, then add water.
This all started happening after the inlet in my radiator busted off and I replaced it with one out of a GST I had laying around.
I have checked for leaks, replaced the thermostat, and bought a brand new radiator... And I still continue to have this problem.
Thank all of you for any help you can provide,
Tyler
Offline
Related Auctions
Sponsored Links
Old 10-28-2004, 03:29 PM   #2 (permalink)
Proven Member
DSM_23's Avatar
Region: Midwest
Reputation: DSM_23 is an unknown
Maybe a bad Temp. Sensor?
____________________________
Justin- Evo Powered TSi AWD
Offline
Old 10-28-2004, 03:31 PM   #3 (permalink)
Proven Member
The car is actually overheating, not just a bad reading.
Offline
Old 10-28-2004, 03:33 PM   #4 (permalink)
Proven Member
Classifieds Rating: (3)
Reputation: ChrisFlo is more helpful than not
have you checked the water pump?
Offline
Old 10-28-2004, 03:36 PM   #5 (permalink)
Proven Member
What are some signs of a bad water pump? When I open the cap and turn the car on it eventually starts to flow.
Offline
Old 10-28-2004, 04:25 PM   #6 (permalink)
Moderator
Defiant's Avatar
Classifieds Rating: (1)
You may have a failed impeller in the water pump. How old is it?
Offline
Old 10-28-2004, 05:09 PM   #7 (permalink)
Proven Member
I am not sure how old the waterpump is. How hard is it to replace?
Offline
Old 10-28-2004, 05:16 PM   #8 (permalink)
Proven Member
Reputation: Erics_silver2g is an unknown
car overheating
if it was a problem with the water pump shouldnt it be blowing cold air when you turn on the heater? because the pump wouldnt be pushing hot water through the heater core?
Offline
Old 10-29-2004, 11:03 AM   #9 (permalink)
Proven Member
I am going to go ahead and replace the water pump. If anyone has any advice on the install I would greatly appreciate it.
Offline
Old 10-29-2004, 11:34 AM   #10 (permalink)
Proven Member
Region: Pacific Northwest
Reputation: ADrewzki is pretty helpful and trustworthy
Quote:
Drain coolant (duh). Take off the necessary parts to get the timing belt cover off. Take off the pulley for the water pump (10mm). The bolts for the water pump will be a pita to access. For a 6 bolt, just make sure you get a gasket for the 1g. Nothing really too tricky about it imho.
Offline
Old 10-29-2004, 04:01 PM   #11 (permalink)
Proven Member
ECLIPSEESPILCE's Avatar
Region: Midwest
Reputation: ECLIPSEESPILCE is an unknown
Before doing a water pump make sure there are no internal head gasket leaks. Your coolant might be going into the engine and out the tail pipe.
Offline
Old 10-29-2004, 04:03 PM   #12 (permalink)
Proven Member
We did a compression test and we got 130-150 across the board.
Offline
Old 10-29-2004, 04:15 PM   #13 (permalink)
Proven Member
Region: Midwest
there is a kit that has a resivoier that is filled with a special liquid that is placed in the radiator fill hole. It allows you to draw air from the radiator to check for exhaust gasses.
It is called a block test.
http://www.arrowheadradiator.com/hea..._leak_test.htm
Here is crummy link but it shows the tool.
call around to a few shops and they might have one.
It only takes a few minutes to do.
Offline
Old 10-29-2004, 10:09 PM   #14 (permalink)
Proven Member
Reputation: realitytb is an unknown
water pumps are way easy. make SURE THAT YOU REPLACE TIMING BELT ALONG WITH IT!! its a must.
But one sign to see if the pump is bad, wiggle it a bit. if it wiggles, then its bad. also, check the pressure in your radiator. i know that i had severe over heating problems after my car was painted, becuase my radiator got plugged from the dust related to painting my car. Also check your thermostat. if its bad, then thats an easy fix for most over heating problems.
Offline
Old 11-01-2004, 09:29 AM   #15 (permalink)
Proven Member
Isn't this tool used to find out if you have a bad head gasket? If so, wouldn't I see if it was bad when I did a compression test?
Offline
Old 11-01-2004, 09:34 AM   #16 (permalink)
Proven Member
Thank you realitytb and everyone. I am going to replace the water pump this next weekend.
Offline
Old 11-01-2004, 05:01 PM   #17 (permalink)
Proven Member
Region: Midwest
I have seen bad head gaskets when a compression test is good. When hot some act different than others. Kinda a stupid question but when you installed the other radiator did you connect the cooling fans? I am not trying to offend you but i have seen it happen.
Offline
Old 11-01-2004, 05:06 PM   #18 (permalink)
Proven Member
Yeah I am sure I connected the fans. I have also checked to make sure it is kicking on.
Ok, that may make since. I seem to loose boost after my car warms up... Could this support your thery that it may be bad only when it gets hot?
Offline
Old 11-01-2004, 05:19 PM   #19 (permalink)
Proven Member
Region: Midwest
I have seen some pretty strange things and it is possible. I just dont want to see anyone waste time and money replacing good parts.
Offline
Old 11-01-2004, 05:23 PM   #20 (permalink)
Proven Member
highpsi93tsi's Avatar
Reputation: highpsi93tsi is an unknown
you might have a blown headgasket. My water pump is fvcked. Leaking water out the bearing/seal under the pulley faster than I can put it in it. Shitty deal. Ive replaced the whole cooling system on this car after I do the water pump.
Offline
Old 11-05-2004, 12:51 PM   #21 (permalink)
Proven Member
Can a head gasket that is only bad when it reaches a curtain temperature lower boost pressure? I have boost when the car isn't warmed up but when it does I don't. Also, if it was the head gasket shouldn't the oil be milkey?
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.23177600 seconds (85.02% PHP - 14.98% MySQL) with 9 queries
