Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 10-22-2004, 12:37 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Krmnnghia is an unknown
Overheating after T28 install
OK so fixed the Oil Pressure problems after T28 install...was a stupid loose wire!!! Now after about 10 minutes of driving we parked it and noticed the top radiator hose was holding pressure...the hose was sucked in and no longer round. We undid the radiator cap and it went back to normal. took it for another spin and no issues..Cool. Next drive the Water Temp gauge is going up more than normal. On the way home it went up so high I could see the entire symbol in the middle so the needle was just above that. Any ideas? The fans are turning on so I know the system seems to be working normal. Could the Banjo bolts be backing up the flow or anything. Its the only part of the cooling system I messed with. Thanks Guys!
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 10-22-2004, 04:25 PM   #2 (permalink)
Proven Member
Reputation: troysevo16 is an unknown
did you happen to install a fmic with your turbo if so the radiator may be having trouble getting air, try changing the thermostade, it would be a wise investment to upgrade the radiator to a better cooling one and some high circulating fans would be a good investment, if you dont want to spend the money remove the ac and the ac core that should help get some air back to the radiator!
Offline
Old 10-22-2004, 09:55 PM   #3 (permalink)
Proven Member
OK Seems I lost more coolany than I thought during the install. It was so low it wasn't cooling enough. So I added more water/coolant to the proper level and bingo! We are golden. HOLY SHIT the power is amazing! THANKS
Offline
Old 10-22-2004, 11:30 PM   #4 (permalink)
Proven Member
No problem, It seem like the more I get to know dsm most problems are cause by something small, or something you happen to overlook the first time!
Offline
Old 10-23-2004, 12:03 AM   #5 (permalink)
Proven Member
Reputation: saw wave analog is an unknown
no, its crankwalk. its always crankwalk if its a 2g. duh.
Offline
Old 10-23-2004, 12:33 AM   #6 (permalink)
Proven Member
yeah 4 2g's your right all though I know a lot of 2g's(friends and know people that have them and me) and I have yet to see one have crank walk (knock on wood) although I have seen many 2g's blow motors because of bad tunning, running to much boost and hp on stock internals and other things...
Offline
Old 10-23-2004, 12:43 AM   #7 (permalink)
Proven Member
Reputation: R3dR is an unknown
make sure you have a spring in the upper hose as you said it went out of round so I assume there is not a spring in it.
If the level is low and there is not a spring it can flaten out the hose and make the temps go to high too.
Offline
Old 10-23-2004, 04:58 AM   #8 (permalink)
Proven Member
WHOA...A Spring in the upper Hose? Ummm seriously? Where would that go! Since adding the coolant and doing 3 30 minute drives it has not compressed again. I think we are ok.
HAHAHAH LOOK OUT IT MUST BE CRANKWALK! HAHAH Thanks guys
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.13391399 seconds (72.21% PHP - 27.79% MySQL) with 9 queries
