starting issues..
1gen2genLaser
49
Oct 10, 2004
Canton, Ohio
I turn the car over and it will hesistate to start.
any quick diagnosis for this?
it will do the "der der der vrooom"
thanks.
Well it could be that too. If your car is turning normal, and firing up is an issue, than it's something else, but if you have a slow start, kinda as if it were dragging, then that is starter or battery. The starter isn't hard to replace, it's just hard to get to.
My 2g started doing the same thing recently as well. Recent is relative because I stopped driving it everyday so if it sits for a week or so it take a sec or so to get it to fire up. I dont think its the plugs because I changed to those to the ngk br6's. Also ran a bottle of injector cleaner in the gas tank. Also timing isn't variable with a 2g CAS. Any ideas?
PS Should I log a specific parameter with dsmlink?
