shoota143
- Jul 9, 2004
Cherry Valley,
Illinois
car will idle around 500rpm, idle does vary from up to 1100 down to 400, but is at 500 most of the time. After i start the car it will idle roughly missing every regularily. if i rev the engine it will die 90% of the time, doesnt matter how high i rev. i was told the timing might be off, i find this hard to believe b/c i just changed the timing belt 3 weeks ago and marks were lined up. i put in new plugs and plug wires..could it be the coil? ECU? wanna check b4 i buy anything..and info helpful Thanks!
Edit - i also have alot of shaft play in my turbo
