4g63mightymax
- 211
- 3
- Oct 2, 2002
Townsend,
Massachusetts
This is a story of a car that cannot be fixed......if you can figure it out, You are my hero forever. You also deserve some sort of lifetime achievement award.
A few weeks ago I posted this problem, and I was told it was the ECU, and I agreed......got a new ecu, and I still have the problem. Here is the Story...
My friend was driving his 95 Talon AWD 5 speed when it started to sputter and cut out. He tried saving it by pushing the clutch in and reving it up, but it died as soon as the clutch was pushed in. He then started the car back up, pushed in the clutch and the car died.....so he did it again.....he did this three times while waiting for the tow truck.
It is then towed to my house because I am his local DSM mechanic (never again). I find that the car has no spark, and no fuel (which is odd since he started it 3 times). The MPI relay is working, the coil gets power, but the ECU doesnt seem to be grounding it like it should. Same deal with the Fuel Injectors, they get power, but dont pulse because there is no grounding through the ECU. I tried a different coil and power transistor with no luck.....I replaced the ECU and it sparked the plugs and pulsed injectors for about 10 seconds of turning the engine over......then it stopped and wouldn't spark again. At this point I was baffled so the car sat for about 3 days. After a few days of thinking, I went back out and turned the engine over and it had spark and fuel again!........but only for about 10 seconds.....then it was gone. This has happened 3 times.
The question is: Why does the car spark and pulse fuel correctly for 10 seconds and then quit for 3 or 4 days.......and miraculously start sparking again for another 10 seconds.
I have checked all major grounds, the fuel pump turns on, all the fuses are good.
ANY HELP OR IDEAS IS GREATLY APPRECIATED!!!!
Thank you very much in advance!
Jeremy
Jeremy
