Eclipse STU STUUU STUUttERING please help!!!
91talonontsi
49
Sep 16, 2004
chester springs, Pennsylvania
ok here it is. i already have a N/T talon but i am looking at buying a turbo car. i found one i really like but it needs some work. the guy says it is studdering and backfiring and alot at 5000rmp. he thinks it might be a missing, but he hasn't had the time to really get into it. so what i was thinkin is, get the car and change out the coil pack and wires from my talon to the eclipse. to see if it would work then. other then that, what else could cause studdering in a motor. i mean i really think it is ignition if it is studdering, backfiring. the only other thing that i could think of is the timming might be off but im just not possitive. im not that firmillar with eclipse motors. do you think before i buy it that it could be anything serious and alot of money. so please any suggestions?? :thumb:
Have the code pulled. If it was a random misfire, another possibility is the power transistor unit. It was on mine and I was able to finally fix it. :thumb:
boost leaks not that i no of. but that would just cause a loose of power right??? it wouldn't cause the motor to studder, would it?
THE WORD IS - S T U T T E R.
There is NO "
STUDDER".
stut·ter
intr. & tr.v. stut·tered, stut·ter·ing, stut·ters
To speak or utter with a spasmodic repetition or prolongation of sounds.
n.
The act or habit of stuttering.
dammit. :rolleyes:
Meanwhile, have him install a new set of wires and plugs, and have a shop pull the error codes.
