Electrical Problem
Alchemy98
126
May 29, 2004
El Paso, Texas
ok i was taking out parts in my car to paint, and while i was following a wire i heard a weird noise and my dome and trunk light went out, they wont work at all. I dont know wut happened, i tryed replacing the bulbs but it still doesnt work with new bulbs in it. Can someone please help me out with this?
Yep, probably just blew a fuse. I believe its in the drivers kick panel...it is in my 2g GSX, so I would assume its the same. If you replace the fuse and it blows again when you use the light or just out of the blue, I would suspect you have a positive wire touching the frame (ground) thereby shorting out the system and blowing the fuse.
