DougEFresh
- 47
- Dec 5, 2002
I have a 91 tsi that i cant seem to get to run right. when you hit the gas and the turbo spools it misses badly blows black smoke and bucks. I read all the hints i could find so i started with checking for boost leaks and i found a few the hoses near the thermostat were leaking and the pcv valve hose was leaking so i used the diagram from taboo and blocked off the uneccisary lines and ran the pcv valve to a catch can. still bucking and missing. so i did the next thing changed the plugs to new ngk's gapped to .028 new ngk wires and a diffrent coilpack still bucking and missing. the car is bone stock with just under 100k on the odo. does anyone have any other things i could try to fix this problem thanks for any help.
id at least check into it....i wouldnt say that going fro cold to hot would affect it though...at least not enough to make it buck and miss...good luck
