QuickSilverGSX9
- 123
- Mar 9, 2003
Fairfax,
Virginia
My transfercase is leaking at the driveshaft, there's gear oil all over the exhaust and undercarrige of the car. I found this out because I was checking the rear end for a noise I heard earlier in the day. I had all 4 wheels off the ground, put the car into first and slowly let off the clutch and the car actually stalled out. I had to give it gas to make it not stall, anything below 1,500 rpm's and the rear wheels wouldn't turn. So, I checked the oil level in the x-fercase and it was pretty much non-existent and then filled it up. After that, the rear wheels would turn like they should, and the car could be in first gear without me giving it any gas and it wouldn't stall. Now, my question is, what possible consequences would result from a dying transfercase? Also, what is the chance that my transfercase is still o.k. (as in not have to replace)?
-Bill
-Bill
