knock on rev
LTQuick
157
Apr 13, 2002
Turlock, California
I just got my datalogger cord a few days ago and hooked it up using mmcd to log. As soon as I installed it and figured out the logger I notice that when I rev in neutral and accrelaerate quickly from a low rpm in first and sometimes second gear that I knock. Does anyone know what may be causing this? Is it a fuel filter? And am I really hurting my eninge bad driving it like this?
Thanks
I think I can log O2sensor voltage, wich is the same thing. But why would I be running lean more on a neutral rev than when I hit boost. If I take off from like 2.5k and hit boost it doesn't knock.
The O2 voltage is usally between .85 and .9 on most knock instances, making it look unrealted to running lean.
