is the manual wrong
ballagsx
143
Jan 31, 2004
Keizer, Oregon
i am removing the head on my 1990gsx. the hains manual says that you need a 13mm hex tip socket. the problem is that it is almost imposabe to find a 13mm. after checking on the forum i have discovered taht some people say that the manual is wrong and it is actualy a 10mm and others say that they used a 13mm.
so who thinks it is what?
so then the pattern seems to be that the 6bolt heads are 13mm and the 7bolt heads are 10mm?
the last and only talon that i have removed the head on didnt need a hex at all, but i am coming to think taht that may not have been the original head and bolts.
what do you think would happen if someone emailed haines.
i think i will di taht and tell you guys what happens.
i dont know if they dould even have anything to say about it though.
so i think taht it is settled. the head bolts are 10mm and not 13mm. the manual is wrong.
Mod edit: it is actually 10mm SOCKET HEAD, which requires a 10mm Allen tool -Leon (didn't want to bump an old thread)
