Starting Problem
mmughal
40
Dec 7, 2003
Dubai, Asia
Hi Guys,
Need some Help, Car was fine whole day, came home and went out again. starts normally , then after that it just doesn't starts properly.
Ignition is there. Engine Starts I give race, RPM is moving then next second. RRM comes to IDLE and then dies.
what could be the problem guys, what should I be diagnosing?
Regards
Mansoor
This is all over the boards if you search. It sounds like its a crank angle sensor(CAS) going bad.
HI
I took it too a mechanic. he checked, and call me now to tell me that
its a burned ECU :cry: could this be it??
Regards
Mansoor
Your caps leaked onto the board. They last about 7-10 years or so reliably and it is advised you replace them for the $2 it costs before this happens.
