wagman
- Nov 19, 2003
I recently just overhauled my car, changed the timing belt, the crank seals, the valve stem seals, new water pump. After everything was installed, the car ran fine without anyproblems, then two weeks i would be driving and u hear a click coming from the fuel pump relay and it would shut down. WEll i changed the fuel pump relay and that wasn't it, then i changed the crank angle sensor, the fuel pump, modulator and ignition coil, but the car keeps shutting down on the highway and locally, i seriousl need some help. T Hanks
