greydelta38
- 139
- 1
- Sep 25, 2012
Huntsville,
Alabama
Hey guys,
I removed SAFC2 from my ECU in a 1997 GST and accidentally split the pinout 90 which is the 'volume air sensor' I think. I'm guessing that is related to the MAF. Anyway, I took another large guage wire and attached the 2 split ends with it.
I assumed it would work fine, the connections looked good. But I started the motor and it runs awful, and won't rev over 1500 which is no doubt a maf issue.
I want to get some ideas as to what the issue may be before I dive into it and start replacing wires and sensors. I'm guessing I just didn't use the right wire or get a good connection on it? It's the blue wire with yellow stripe going into the top connector on the ecu.
Thanks
Thanks
