turboAWDfanatic
- 347
- 35
- Aug 22, 2005
Colorado Springs,
Colorado
I'm in the process of figuring out why my car is leaning out at 5,500 rpm, and I have a specific question about the AFC. By logging w/ Zeitronix I've been able to see what my true A/F is, but yesterday I started looking at the "cor" display meter on my AFC. I've noticed that during WOT 3rd gear pulls to 6k rpm, the "cor" gauge display peaks at around +7% to +8% even though I've set the 5k, 6k, and 7k points on the air map to +12% and up. I figured that maybe I needed to set my "high throttle" point at lower than 80% so the AFC would correct sooner, but changing that doesn't help.
Why would my AFC only be correcting up to +7% even though I have set the air map to correct +12% and higher in the 5k-7k range?
