Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
View Poll Results:
0%
Voters: 0. You may not vote on this poll
Reply
LinkBack Thread Tools
Old 02-26-2008, 10:23 PM   #1711 (permalink)
New Member/Lurker
Region: Midwest
Classifieds Rating: (0)
Reputation: MHI Superhero is an unknown
My name is Chris and i guess that i am a noob . I came across this site when searching for information regarding the MHI TE06-24V turbo. Originally I was only planning on posting on the thread where they were discusing it but since I'm new I guess that isn't possible.
http://www.dsmtuners.com/forums/turbo-system-tech/215275-new-mitsubishi-turbo-tdo6h-24v.html
my car- 91 Eagle Talon TSI
engine mods
4g64 stroker crank
Eagle H beam rods
JE forged stroker pistons
272 hks cams
Manley springs/retainers
driveline mods
Shep Stage 1 tranny w/ 4 spider
ACT 2900 w/street disk
4 bolt rearend
exhaust/intake mods
Punishment racing SS o2 housing with Tial 38mm wastegate
FP 4" cast aluminum intake
Evo 3 exhaust manifold
Extrude honed stock intake manifold
HKS SSQV BOV
Ebay special 4" thick intercooler
Tuning mods
Socketed eprom ecu
Hacked 2g maf
950cc injectors
Walbro 255HP fuel pump
Innovate LM-1 wideband
Turbo setup
MHI TE06 24V turbo
Compressor (50trim) = inducer- 55mm exducer- 77mm
TD06H exhaust wheel
FP ported 7cm exhaust housing machined for TD06H wheel
It is a genuine MHI turbo complete with a part number (49185-01523). It isn't watercooled like most MHI's and has Garrett style feed/drain flanges. The center cartridge isn't clocked correctly in that pic because that is when i first mocked it up. It may have some dirty fingerprints on it but it is actually new and set me back only 650$ shipped from Japan. I believe that this turbo was designed to replace the 25G and originally was put on some large diesel truck. I hope to squash the FP green
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 02-27-2008, 11:45 AM   #1712 (permalink)
New Member/Lurker
Timeslip: 14.509 @ 93.140
Region: Midwest
Classifieds Rating: (1)
Reputation: jstgon is an unknown
2G-specific
Hey I don't know if I have posted on here yet to introduce myself so here I go. I'm Joe I am 21. I drive a 95 talon tsi awd, and the daily is a 2003 ford focus svt. The talon is looking to be a 12 second daily driver for now. Have a Evo III 16g waiting to put on it. New 2g pistons, and going with 1g Big rods. When i was younger, (I have had the car for four years this year. I was racing a marauder on the highway and well I won but my car died. carnage pic later.) Have supposrting mods to go 12.5xx. And the car is an automatic, don't just got to love consistent reaction times. ran 14.5 completely stock. Now for some pics.
carnage!!!
Offline
Old 02-27-2008, 12:53 PM   #1713 (permalink)
Proven Member
jusmx141's Avatar
Region: Tri State
Classifieds Rating: (7)
Reputation: jusmx141 is extremely helpful and trustworthyjusmx141 is extremely helpful and trustworthyjusmx141 is extremely helpful and trustworthy
Quote:
The Green is simply a 50-trim Garrett wheel shoved into a 20G compressor cover. It is built to suit a certain requirement as far as efficiency is concerned. I'm sure if FP thought your 24V would've been a better model to base the Green around, they would've done so.
Basically what I'm saying is you're comparing two turbos that may provide two different spool characteristics and powerbands. The Green's compressor wheel is rated at 700cfm, while yours is rated at 800 under a much larger cover. I could sit here all day and post things like "I hope to squash a 14B with a TD05H 20G!!!!" but no one would respond because they'd think I'm retarded.
____________________________
~Justin~ '92 TSi FWD, '93 TSi AWD, '97 Eclipse GS
Offline
Old 02-27-2008, 01:02 PM   #1714 (permalink)
New Member/Lurker
Region: Midwest
Well both the Green and the 24V are 50 trims and both use td06h exhaust wheels. The 24v is just 2mm bigger all around on the compressor. I only compare it to the green because that is what i consider it closest to. This turbo isn't a straight up bolton turbo like the green because it requires waterpipe modification due to its larger compressor cover. Between having a 2mm larger inducer/exducer and a map width enhancement groove it should serve the green badly. I doubt FP really cares because they have the 3052 and 3065 and the 24V can't touch those. Hybrids are pretty old in the grand sceme of things. This is just the next step beyond the 20g. Post this info in the general forum and see how many people are interested....
I'm just comparing a MHI turbo to a hybrid of nearly the same size. I don't think i sound like the retarded one....
Offline
Old 02-27-2008, 07:03 PM   #1715 (permalink)
New Member/Lurker
Car: Mitsubishi Mirage Evo swap
Region: Tri State
Reputation: whodizking is an unknown
Hey whats going on im from New Jersey and i just got on this DSM site because im about to buy myself a 2nd gen Eclipse GSX with a 6 bolt engine. Im going to make time to go cheeck it out first to make sure everything is good. Any advice i will take into consideration. I also own a 1997 Mitsubishi Mirage Evo 5 swap converted FWD. Check out and im also selling if anyone knows someone looking for a fun car.
Offline
Old 02-27-2008, 07:13 PM   #1716 (permalink)
New Member/Lurker
Region: Midwest
Quote:
Thats a pretty cool setup. Did you ever get a chance to weigh it?
Offline
Old 02-27-2008, 07:21 PM   #1717 (permalink)
New Member/Lurker
Region: Tri State
The mitsubishi mirage weights in about 2400 pounds witch is pretty light and can get lighter very fast too lol.
Offline
Old 03-02-2008, 05:22 PM   #1718 (permalink)
New Member/Lurker
Region: Southeast
Reputation: M3BEAST is an unknown
Hi i am Joe Mile
29 yrs old
Drive a gsx as picture shows
Offline
Old 03-03-2008, 09:40 AM   #1719 (permalink)
New Member/Lurker
fod247's Avatar
Region: Southeast
Reputation: fod247 is an unknown
Hey My names Matt. I just bought this thing for a huge $850.00 and plaining on fixing it up and puting to much money into it. well thats what the wife says anyway.
Offline
Old 03-03-2008, 01:15 PM   #1720 (permalink)
New Member/Lurker
Region: Tri State
Reputation: aj2007 is an unknown
Hey,
I am pretty new here. I hope to be buying a 95+ talon or eclispe very soon. If you or anyone you know if wanted to sell around the NJ,NY,PA,CT area please let me know. I'm going to start reading up on the forums now.
Offline
Old 03-03-2008, 04:29 PM   #1721 (permalink)
Proven Member
GSX4BangR's Avatar
Region: Tri State
Reputation: GSX4BangR is an unknown
1G-specific
Yo, im marcellus and i live in naptown, indiana and i drive, well am working on, my 1991 eclipse gsx, im 22 years old bout to be 23. I love dsm's with a passion and the skyline gt-rs and evo's. Im currently working at brightpoint trying to modify my car to run 11's
Offline
Old 03-03-2008, 11:33 PM   #1722 (permalink)
New Member/Lurker
Region: NorCal
Reputation: 4g37NonTurbo is an unknown
hey I'm adam and i drive a 91 eclipse 1.8SOHC =(
i need some serious help on anyone who has knowledge about it.
I want to turbo charge it but also engine swap....I don't know which would be better or if turbo chargin is possible with the 1.8SOHC....need some serious feedback on that
Offline
Old 03-04-2008, 06:44 AM   #1723 (permalink)
New Member/Lurker
Car: 1992 Eagle Talon TSi AWD
Region: Eastern Canada
Reputation: Ice Racer is an unknown
Hi all,
New to the forum and new to DSM's. In fact, I haven't bought one yet but I'm in the market for a 1G AWD for ice racing. Just checking the site for best preventative maintenance practices and mild power upgrades.
Thanks.
Rod
Offline
Old 03-04-2008, 12:53 PM   #1724 (permalink)
New Member/Lurker
AlphaVision's Avatar
Region: Mid Atlantic
Reputation: AlphaVision is an unknown
2G-specific
Greetings from Bulgaria!
I'm Leo - 26 years old from Sofia, Bulgaria. I drive an European 1999 Eclipse GS. They come with Non-Turbo 7bolt 4g63. Here in Europe the turbo DSMs are very rare as well as the engines. Well that engine got totaled so now I am doing an 1g motor swap (4g63 turbo). I think my engine is 6 bolt. I bought it yesterday and still haven't removed the clutch yet.
I solute everybody for being part of this great forum! DSM Rules!
Leo
6bolt 4G63T with 1G ECU in a '99 NA 4g63
Offline
Old 03-05-2008, 06:10 AM   #1725 (permalink)
New Member/Lurker
Region: New England
Reputation: Empire3212 is an unknown
Hi My name is David
I have a 95' Gst That I use as my daily driver.
I have been into DSM's for a few years but am still learning more and more everyday.
Offline
Old 03-05-2008, 06:06 PM   #1726 (permalink)
Proven Member
GSX4BangR's Avatar
Region: Tri State
1G-specific
Ay wussup 4g37nonturbo, It would be a pita to try and turbocharge a 1.8l. It is possible to swap the motor, but the money you spend doing the swap, you could easily sell the car and buy a turbo eclipse. Especially one with AWD
Offline
Old 03-05-2008, 08:24 PM   #1727 (permalink)
Proven Member
talintidturbo91's Avatar
Region: Midwest
Reputation: talintidturbo91 is an unknown
hi, my name is michael knight. (19) i drive a 91 awd tsi. No i do not call it kitt, because it is white. I live in the (up) upper penninsula of michgan.
Offline
Old 03-06-2008, 01:01 PM   #1728 (permalink)
Proven Member
Region: Southeast
Reputation: totaleclipse3 is an unknown
Hey guys My name is John Collins and I have been a member of this forum for some time now and I've never officially introduced myself. I'm 21 years old and I drive a 97 mitsubishi eclipse gst, it's my third dsm. I really have learned a great deal about my car from searching around these forums and I would like to start contributing to this site more frequently and figured a good place to start would be right here.
Offline
Old 03-06-2008, 04:39 PM   #1729 (permalink)
New Member/Lurker
Reputation: Siwel is an unknown
Not new to DSM's.. my 2nd one.
I got rid of my 1st gs-t because it was half assed/hacked/half assed when I had gotten it. I got tired of tracking down stuff and figured one day I might find one that was stock so I knew what was/wasent done to it. Well, today was that day.
Just got a gsx.
Anyhow yea, im new here..
Offline
Old 03-06-2008, 07:51 PM   #1730 (permalink)
New Member/Lurker
Sewey_GSX's Avatar
Region: Midwest
Reputation: Sewey_GSX is more helpful than not
How's it going, my name is Matt
I live in Hartford, MI
Just picked up my 99 gsx!
Can't wait for summer to get here and start working on my car
Offline
[posts] [
