Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 10-02-2006, 06:39 AM   #1 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (-2)
Reputation: freshlane isn't as helpful as most
Thumbs up 1G to 2G MAF Upgrade chart
I went around on the internet and just put together this little chart on the MAF conversion. Please feel free to reply with edits. (ps the "=>" indicates what it will connect to on the other harness.)
1G TURBO MAF
1 - Idle position switch
2 - Air flow sensor (signal)
3 - MPI control relay
4 - 5V power supply
5 - None
6 - Ground
7 - Barometric pressure sensor
8 - Intake air temperature
1G N/T MAF
1 - Air flow sensor (signal)
2 - MPI control relay
3 – 5V power supply
4 – Ground
5 – Barometric pressure
6 - Intake air temperature
2G TURBO MAF
1 – 5V Power supply
2 – Barometric pressure
3 – Air flow sensor
4 – MPI control relay
5 – Ground
6 – Intake air temperature
7 – Volume Air Flow
CONVERSION: <1g nt MAF -to- 1g turbo MAF>
Pin2 1g Turbo MAF => Pin1 1g NT MAF
Pin3 1g Turbo MAF => Pin2 1g NT MAF
Pin4 1g Turbo MAF => Pin3 1g NT MAF
Pin6 1g Turbo MAF => Pin4 1g NT MAF
Pin7 1g Turbo MAF => Pin5 1g NT MAF
Pin8 1g Turbo MAF => Pin6 1g NT MAF
CONVERSION: <1g turbo MAF -to- 2g turbo MAF>
Pin1 1g Turbo MAF => ?
Pin2 1g Turbo MAF => Pin3 2g Turbo MAF
Pin3 1g Turbo MAF => Pin4 2g Turbo MAF
Pin4 1g Turbo MAF => Pin1 2g Turbo MAF
Pin5 1g Turbo MAF => - (doesn’t seem like it will be used)
Pin6 1g Turbo MAF => Pin5 2g Turbo MAF
Pin7 1g Turbo MAF => Pin2 2g Turbo MAF
Pin8 1g Turbo MAF => Pin6 2g Turbo MAF
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09619999 seconds (67.30% PHP - 32.70% MySQL) with 9 queries
