| Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section. |
05-21-2007, 06:30 PM
#61 (permalink)
Proven Member
Region: Midwest
Quote:
Originally Posted by snox135
What flywheel is that? I swear my Fidanza has the steps machined into it
It's from an EVO
Offline
09-13-2007, 01:00 PM
#62 (permalink)
Proven Member
Region: Tri State
i know this thread is old but i thought this might help some people trying to find a definet answer. Well I contacted fidanza themselves to see if stock flywheel bolts are ok and I also asked about useing a spacer. I got this:
Hello,
Thanks for contacting Fidanza. Yes, you can use the stock bolts. Our flywheel is designed to the same dimensions as the stock flywheel. Also, you can use washers, but they are not necessary.
Thank You,
Brad Bojc
Fidanza Engineering Corp.
4285 Main Street
Perry, Ohio 44095
Offline
11-22-2007, 09:27 PM
#63 (permalink)
New Member/Lurker
Region: Mid Atlantic
Oil pan bolts fell off, got wedged in flywheel :)
So I had an oil leak, I was looking for it today after removing my power steering system. I look inside the transfer case, where the oil pan goes up underneath it and the two bolts you can see but cant get to, are missing. and thats where my oil leak is, obviously.
so tomorrow, I get to remove the transfer case, drop the oil pan, and make sure my car is still alive. it better be, the motor only has about 1000 miles on it. I bought the car with the new motor already in it, so this will be my first time doing this. Anyone have any advice I might need to know before I do this?
thanks
-James
Offline
11-22-2007, 10:00 PM
#64 (permalink)
New Member/Lurker
Region: New England
You've got the right plan. The transfer case is relitivly easy to remove. I just wanted to remind you that when you put your oil pan back on there are two of the oil pan's bolts that are shorter than the rest. They go under the crank pulley for your timing belt. If the longer bolts get put under it they will rub on your Tbelt. Also I would look into why the bolts fell out in the first place.(stripped threads?)LOC TITE is your DSMs friend. GOOD LUCK!!! I hope this is usefull.
Offline
11-22-2007, 10:15 PM
#65 (permalink)
New Member/Lurker
It is helpful, and I definately will use loctite. and I'll make sure I note the shorter bolts go where they should. I'll update the thread when I'm done. I'm going to get a new gasket at autozone tonmorrow and hopefully get some new bolts for the oil pan.
Offline
11-22-2007, 10:58 PM
#66 (permalink)
New Member/Lurker
When I put the new gasket on do I need to use RTV sealant too or just the gasket alone?
Offline
11-22-2007, 11:05 PM
#67 (permalink)
Proven Member
Region: Midwest
Use RTV on both sides of the gasket. Make a nice thin layer on both sides and you'll be good to go.
____________________________
Nick
Offline
11-23-2007, 12:51 AM
#68 (permalink)
New Member/Lurker
ok cool, thank you for the info sir.
Offline
11-23-2007, 01:18 PM
#69 (permalink)
New Member/Lurker
Region: New England
Be sure to get the same length bolts that where used. The main seal housing's threads are only so deep. If your new bolts are longer they could bottom out and the threads could strip or the aluminium housing could crack!!!!
Offline
03-23-2008, 04:26 PM
#70 (permalink)
Proven Member
I just went and measured my FIDANZA Flywheel and My stock Flywheel. They are 100% without a doubt the SAME.... The bolts go through to the Crank exactly the same.... I havn't a clue who couldn't measure and started this rumor... But I just want it clear that the FIDANZA FLYWHEEL does not need any Longer bolt....
Offline
03-23-2008, 05:22 PM
#71 (permalink)
Proven Member
Region: Midwest
Quote:
Fidanza has made several revisions to the part since I've been using them, perhaps this is yet another
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
