Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 04-28-2006, 09:46 AM   #31 (permalink)
New Member
Classifieds Rating: (0)
Reputation: girlpower92 is on thin ice
hey thanks for the help
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 04-28-2006, 10:09 AM   #32 (permalink)
Proven Member
Scott_S's Avatar
Region: Midwest
Reputation: Scott_S is more helpful than not
94-101 ft/lbs
I see its already been answered, my bad
____________________________
-Scott
Offline
Old 05-18-2007, 05:31 PM   #33 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (2)
Reputation: -DSM2NR- is pretty helpful and trustworthy
Is anyone using their stock bolts on a Fidanza flywheel?!?
I've read a couple of threads saying that you have to use longer bolts to fit the Fidanza flywheel so the bolts wouldn't back out. Is anyone using the stock bolts with their Fidanza? Any problems with that?
Offline
Old 05-18-2007, 06:25 PM   #34 (permalink)
Proven Member
JamiesTSI's Avatar
Region: Tri State
Reputation: JamiesTSI is more helpful than not
I use the stock bolts on my Fidanza set-up. So-far, so-good.
2.3L G4CP
2.4L G64B
Offline
[posts] [blogs] Reply With Quote
Old 05-18-2007, 06:44 PM   #35 (permalink)
Proven Member
Region: Midwest
when did you install your flywheel? Also, did you use a a/t spacer plate when you installed it?
Offline
Old 05-18-2007, 06:58 PM   #36 (permalink)
Proven Member
Region: Midwest
Reputation: 95-talontsi is more helpful than not
I used my stock bolts as well about 12000 miles on it now.
Offline
Old 05-18-2007, 07:02 PM   #37 (permalink)
New Member
Region: Southeast
Reputation: spydur8385 is an unknown
i used stock bolts also sitting at 4000 miles so far...
Offline
Old 05-18-2007, 07:12 PM   #38 (permalink)
Proven Member
Region: Midwest
did you guys put a a/t spacer plate on?
Offline
Old 05-18-2007, 08:08 PM   #39 (permalink)
Proven Member
Region: Midwest
nope
Offline
Old 05-18-2007, 09:37 PM   #40 (permalink)
Proven Member
Region: Midwest
wow, why do so many people say that their stock flywheel bolts on a fidanza loosen and raise havoc
Offline
Old 05-18-2007, 09:52 PM   #41 (permalink)
Proven Member
nightspeed87's Avatar
Region: Southeast
Reputation: nightspeed87 is pretty helpful and trustworthy
Quote:
2nd that....
Car sold 1-4-2008
Offline
Old 05-19-2007, 10:48 AM   #42 (permalink)
Proven Member
Region: Western Canada
Reputation: VanIsleDSM is more helpful than not
I'm running on stock bolts too.. just use locktite.. if it was a big deal fidanza would be recommending and selling bolts I figure..
That FP kit is crap anyway from what I've heard, the bolts are good.. but definitly don't use the stud kit or whatever it is for the pressure plate.
To be honest I didn't even know when I put my fidanza in that it was 4mm thicker.. if I would have known I may have just bought some high grade bolts from the fastener place but I really don't think it'll be a big deal..
Offline
Old 05-19-2007, 11:04 AM   #43 (permalink)
Proven Member
TALONTRAX's Avatar
Region: Tri State
Reputation: TALONTRAX is pretty helpful and trustworthy
All stock hardware on my 2G Act 2600 & Fidanza flywheel, & no problems at all so far
Offline
Old 05-19-2007, 11:51 AM   #44 (permalink)
Proven Member
Region: Midwest
Reputation: gsx951 is pretty helpful and trustworthygsx951 is pretty helpful and trustworthy
Quote:
Originally Posted by VanIsleDSM View Post
I'm running on stock bolts too.. just use locktite.. if it was a big deal fidanza would be recommending and selling bolts I figure.. ..
Well, in this case, the fastener will not back out (due to the loctite) but will be of little value because it has lost some or all of it's clamping force.
http://www.boltscience.com/pages/basics2.htm
I have found that FP kit to be a bit pricey but to work very well.
Offline
Old 05-19-2007, 11:56 AM   #45 (permalink)
Proven Member
Region: Midwest
Quote:
Originally Posted by -DSM2NR- View Post
wow, why do so many people say that their stock flywheel bolts on a fidanza losen and raise havoc
Ok here the deal in a nut shell:
For bolts to work, they must be preloaded. That is, the bolt must be"torqued" so that it sees an appropriate amount of stretch.
The stretch applies a clamping load on the bolted joint. Remove the preload stretch and the bolt is free to back out under vibration. Remove the preload and the bolted joint is just a bunch of parts held in location.
A bolted joint with the appropriate amount of preload stretch is actually stronger than the sum of it's parts (figure that one out).
When you bolt a Fidanza or other soft aluminum flywheel down, the flywheel surface will actually flow away from the bolt head. When this happens, you lose the preload and the flywheel becomes loose. The A/T spacer prevents this by spreading the load over a much larger area. This is a very good idea because not only does it prevent the losening issue from occuring but it also prevents the flywheel from being damaged as the bolt heads fret or wear into the surface. Fretting is very undesireable, it causes stress to be focused and will promote cracking in otherwise sturdy components.
Offline
Old 05-19-2007, 11:59 AM   #46 (permalink)
Proven Member
marcmsj's Avatar
Region: Mid Atlantic
Classifieds Rating: (4)
Reputation: marcmsj is pretty helpful and trustworthy
stock bolts here too, no problems.
Offline
Old 05-19-2007, 02:06 PM   #47 (permalink)
Proven Member
Region: Midwest
quick question for the people that used stock bolts, did you use a a/t spacer plate?
Offline
Old 05-19-2007, 02:33 PM   #48 (permalink)
Proven Member
boosted spartan's Avatar
Region: Gulf Coast
Reputation: boosted spartan is an unknown
i resused mine..i just put a dab of blue thread-lock.
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 05-19-2007, 03:11 PM   #49 (permalink)
Proven Member
Car: 91 Colt w/4G63 swap
Region: Midwest
Reputation: TwoLiterLaser is more helpful than not
Very good explanation gsx951.
If the a/t spacer is not used the likelihood that the bolts will back out increases. A lot.
Offline
Old 05-19-2007, 03:23 PM   #50 (permalink)
Proven Member
Car: Toyota Aristo Twin Turbo
Region: Outside North America
Classifieds Rating: (5)
Reputation: Raph is pretty helpful and trustworthy
Stock bolts+threadloc ,no probs
Offline
Old 05-19-2007, 09:29 PM   #51 (permalink)
Proven Member
Region: Southeast
Classifieds Rating: (1)
Reputation: Puscifer is an unknown
Very good question of course. I'm replacing my clutch system myself and ordered Fidanza's 8lb alum. flywheel. I went to bolt it up to the crank and what started my curiousity was how far it was off the crank. So, I dug the paper that came with the flywheel and they "suggest" using the 95 flywheel bolts. Didn't specify whether it was a n/a or forced induction application though so it's something to make you wonder about.
Also, after researching and noticing a lot of people commenting about Fidanza's flywheel's being 4mm thicker is very understandable. Out of curiousity I measured mine and came up with very close to the stock measurement. Anyone figure they might've made them more stock spec? Regardless I said definite for the a/t plate. I mean, duh.. if you know what it's for you know it's gonna help. Good luck.
Offline
Old 05-20-2007, 02:03 PM   #52 (permalink)
Proven Member
Region: Midwest
What happened here?
Offline
Old 05-21-2007, 07:10 AM   #53 (permalink)
Moderator
Defiant's Avatar
The bolts held nice and tight.
Online
