spainobain1234
- 1
- Oct 17, 2013
Puyallup,
Washington
4g63 Turbo GST FWD Manual Transmission
Symptoms:
Heavily obvious, I'm driving in any gear when I am 10% Throttle Accelerating, the car bucks like crazy like it is stalling during acceleration. The rpms bounce from 1k-2k rpm, and 2k-3k rpm. In between those RPM ranges, the car bucks even when I am pressing the gas pedal, it is like it Completely cuts the fuel, Rpm's bounce, stops accelerating then kicks back in to accelerate again then bam, no more increase, then rpms drop it slows down and speeds up, bam, while my foot has remained the same constant 10% throttle on the gas pedal.
Every time I accelerate in gear, 10% throttle, the car goes up goes up and STOPS accelerating and makes a clunk while my foot is still on the gas, and the rpm bounces up down and then the car Reactivates in gear and accelerates like it is trying to get back to the same speed then Clunk it stops again and the rpms bounce down and shoot up 1k - 2k 1k-2k car bucking.
The car bucks, and every time I am decelerating, the car bucks at low rpms like 3 times. It goes, buck, buck , buck, and the symptoms are heavily obvious.
Any help appreciated on this thread.
Thank you
Symptoms:
Thank you
