Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management > Log File Advice
Log File Advice Post your log files here for advice.
Reply
LinkBack Thread Tools
Old 05-13-2007, 05:59 PM   #1 (permalink)
Proven Member
Region: Southeast
Classifieds Rating: (0)
Reputation: Glliw is more helpful than not
New log, crazy knock, can't get rid of it.
So I'm trying to tune this bad boy, and no matter what I try with the fuel settings, the knock won't disappear. The mods are:
ExtremePSI 2" intake w/ 2-3" reducer coupler(choking the turbo, killing the spoolup a few hundred )
SBR G50 50 trim w/ turbonetics center section & internal wastegate
SSAuto FMIC with polished short route piping
Walbro 190lph fuel pump
DKS 264/272 cams
3g revised lifters
Prothane Motor Mounts
ARP head studs w/ stock headgasket
stainless steel oil return and feed lines
DSMlink
PTE 880cc injectors
ACT 2100
The boost is set at 17lbs. I tried adding 30% fuel from 4k on up, adding 0%, pulling 5%, adding 5%, adding 15%, etc, etc. But the knock comes out to the exact same numbers each time. It always ends with 12.7 degrees of knock. I can feel the loss of power when the knock comes on from the pulling of timing. Here is a log.
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11256599 seconds (65.65% PHP - 34.35% MySQL) with 10 queries
