Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management > Log File Advice
Log File Advice Post your log files here for advice.
Reply
LinkBack Thread Tools
Old 04-20-2006, 05:12 PM   #1 (permalink)
tjc
Proven Member
Region: Mid Atlantic
Classifieds Rating: (0)
Reputation: tjc is an unknown
First Log
TIMA TPS RPM KNK INJ Duty %
38.00 13.33 2562.50 0.00 0.00
38.00 29.80 2687.50 0.00 22.00
27.00 100.00 2781.25 0.00 25.00
25.00 100.00 2937.50 0.00 31.00
23.00 100.00 3062.50 0.00 41.00
19.00 100.00 3218.75 0.00 50.00
17.00 100.00 3375.00 0.00 52.00
18.00 100.00 3531.25 0.00 54.00
18.00 100.00 3687.50 0.00 57.00
19.00 100.00 3875.00 0.00 60.00
20.00 100.00 4031.25 0.00 63.00
20.00 100.00 4125.00 0.00 67.00
20.00 100.00 4312.50 0.00 71.00
20.00 100.00 4468.75 0.00 74.00
20.00 100.00 4656.25 0.00 80.00
19.00 100.00 4812.50 0.00 84.00
19.00 100.00 5000.00 0.00 88.00
20.00 100.00 5125.00 0.00 91.00
21.00 100.00 5281.25 0.00 93.00
21.00 100.00 5437.50 0.00 98.00
22.00 100.00 5500.00 0.00 97.00
23.00 100.00 5625.00 0.00 98.00
25.00 100.00 5687.50 0.00 101.00
24.00 100.00 5781.25 0.00 101.00
26.00 100.00 5937.50 0.00 105.00
25.00 100.00 5937.50 0.00 105.00
26.00 100.00 6062.50 0.00 106.00
26.00 100.00 6250.00 0.00 109.00
25.00 100.00 6312.50 0.00 110.00
24.00 100.00 6343.75 0.00 112.00
24.00 100.00 6406.25 0.00 112.00
23.00 100.00 6562.50 0.00 116.00
22.00 13.33 6343.75 0.00 8.00
Here is my first log on a 3rd gear pull. Boost is 8-9 psi per autometer gague tapped into intake manifold. Turbo is small 16g, stock FPR, MSD fuel pump (162 lph) and stock 450cc injectors. I have no intercooler. O2 is 0.87 through entire pull. Base timing 5 degrees BTDC. There was a boost leak at the throttle shaft sealers and number one injector gasket (they have all been replaced since this run but I am afraid to do another run with that maxed injector duty).
I am worried about the maxed injector duty and am wondering why that is happening on this essentially stock (not fuwl pump though) set up at pretty low boost.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09830904 seconds (67.04% PHP - 32.96% MySQL) with 9 queries
