Psycron
- 217
- 1
- Jul 29, 2002
Farmington Hills,
Michigan
...So I bought a new, fully built dual piston caliper to replace it. I searched extensively but was unable to find the information I was looking for. What I need to know is this - What is the proper method for replacing just this caliper? Can I just take the caliper off and replace a single caliper then bleed until there is no air or do I have to bleed the other 3 as well? I've never done this before, but I bought a mitey-vac pump to assist me in this one-man job.
I will need jack stands in the front, correct? From the research I've done I can disconnect the caliper, reassemble then bleed and test drive. I'm not sure how I use the vacuum pump, either. Would it be a good idea to flush at this time? I know it will take much longer, but if it's a worthwhile necessity then I'll do it.
Any advice is greatly appreciated.
-Alan
-Alan
According to the manual you start with pass rear, then driver front, then driver rear, and pass front last. Keep a close watch on the fluid level at the master cyl so you don't suck air into the system.
