Coilover height problem?
iroibeirt
71
Aug 20, 2002
i just recently got the TEIN type SS coilover suspension kit for my 99 eclipse GST, immaculate ride none the less, however i noticed that there is a small difference in the wheel/fender gap for each wheel,
basically i lowered it 4 coils (thread marks on the coilover setup) in the front and i lowered it with 6 coils in the rear, so i put the front slightly lower than the rear, being that the less ammount of coils results in a larger drop, however, the distance in the wheel/fender gap is different.
the front left is 1 finger, the front right is a tight 2 fingers,
the rear left is a perfect 2 fingers, while the rear right is a loose 2 fingers,
is this normal? am i supposed to adjust the coilovers to match the ride height? or am i supposed to match the amount of coils? please help thanks
Originally posted by iroibeirt
could someone please put some input haha im kinda lost right now
The engine sits to one side of the car so more than likely there is a weight difference over the two front wheels. My GC's are like that, have someone measure the gap with you sitting in the car then adjust accordingly.
