Problem with Camber HELP!!
96TalonAWD
224
May 3, 2002
Orlando, Florida
i have a unsolved mystery here i got a accident on the front end which of course threw the car way out of alignment. after 4 weeks i look at my passenger side tire and it was really worn out, so i align the car 2 times and put new tires in the fornt. and after 3 weeks of my last alignment the same right side tire is getting noticeable worn out so i dunno what going on.
im suspecting the control arms or something do somebody have went thru this before???
thanks
It sounds like it's not aligned properly or a component is worn out causing the alignment settings to change while driving i.e. ball joints warn.
You say you've had three alignments done. I've got my alignment specs around here somewhere and can go over yours with you if you need more information.
Doug
thats another thing they never gave me the print outs and nothing. if i find out somehting is damage and they didnt tell me they get sew
You can't sue if they don't tell you something is damaged. They do the alignment. They get it in specs. Now if they damge something which cause you to have an accident then maybe you can sue if you can prove it was their fault.
So go sew em up all you want. :thumb:
