Quick Motor Mount Insert Question
99GST
245
Dec 26, 2001
Nashville, Tennessee
I have a couple of inserts that are a bit cracked, and I am feeling a pretty good amount of vibration when accelerating at higher speeds.
So, should I get poly mm inserts? I dont want to have vibrations in my cab, but I want something better than the stock inserts. I plan on adding a big 16g here in next two months. Oh yeah, I am also fwd.
What options do I have?
Thanks,
Nathan
well to be honest with you, if you get just the front and year inserts the vibrations wont be nearly as bad as if you were to get all four of them. I have the front and rear inserts and it has almost stopped the wheel hop and I dont even feel the vibrations anymore. Defintely get them man, they are worth the 2X dollars you will pay for them.
My friend and I completely replaced all of the motor mount inserts in his GS with Extreme turbo Poly motormount inserts. Cost about 95.00
A bit more torque is felt, afterall this is an NT. No more torque loss to mount flex. However the only downside I can name is it is a PITA to swap them out and you can feel alot more engine vibration. No more is produced, just more is felt.
http://www.dsm-performance.com/catalog/product_info.php?cPath=30&products_id=122
