eibachs with these struts?
lowridin2g
904
2
Sep 5, 2002
Pembroke, Massachusetts
could i use eibach or intrax springs with these struts? the reason im asking is because im thinking of switching out my ractive coilovers for some type of spring that will give me like a 1.75 in. drop. it doesnt really look like theres a perch for the spring to sit on and i already have these struts with my coilovers so i dont wanna buy new struts too. i figure nows the time if im gonna switch because im getting my eibach camber kit installed some time next week or the next. so lemme know. also what springs would be good with my 18's? i dont wanna be rubbing. im thinking either eibach pro kit or sportline. i still wanna be low but i cant be rubbing in the rear. kinda a dillema. anybody got pics or suggestions?
those are the struts i first bought with my sportlines, it will sit with about a 2" drop. so you went 2 sizes bigger in rims as long as you went 2 sizes lower in tire diamater they would still be the same as if you had your factory 16" rims with the 205x55x16 tires, so there should be no problem.
205/55/16 was the stock setup now i got 225/40/18 so i went a size and a half lower in sidewall. so yea theres a little difference with my 18's. plus i went with 40 sidewalls beacuse giovanna are expensive rims, i didnt wanna be dinging up those rims ( a little easier to ding up with a 35 sidewall ya know?) so hopefully theres no problem.:dsm:
