jonathanfl
Supporting VIP
- 91
- 4
- Feb 20, 2014
orlando,
Florida
So i was thinking last week i needed something to do since i finished my Avalanche and i had way to much time on my hands, so i spent three weeks trying to buy a decent shell. I had 4 cars in mind specifically for their engines and yes a 420a engine was one of the engines on the list. After being blown off a few times trying to buy a car by different people i was lucky enough to find this shell that looks like the kid who owned it had no clue how to take care of a car. So since last Thursday my research and ordering started.
Luckily the kid had gone through the suspension with adjustable suspension and he actually did it correctly. Ill have to get the names of everything after i start tearing down the front end and ill update.
2/25/14
-Cimotorsports:
Fidanza adjustable cam gear set
Sib pt cruiser style rocker arm set
Brian Crower stage 2 turbo grind camshaft ---------- FOR SALE
Arp main stud kit
2/28/14
-Cimotorsports:
Felpro Lower Gasket Kit Eclipse/Talon 420a
Prothane Complete Engine Mount Kit Eclipse/Talon 420a
PT Cruiser Style Lifter Set Eclipse/Talon/Neon 420a
Felpro Top End Gasket Kit Eclipse/Talon 420a
3/1/14
-Modern performance:
Pci mechanical conversion timing belt kit w/ gates racing belt
3/12/14
-Ci motorsports
Brian Crower stainless steel valve set +1mm
Sbi valve lock keeper set
-Amazon
Arp intake/ exhaust studs
3/13/14
-Treadstone performance
420a turbo kit (discontinued)
Turbonetics hybrid turbo 62-1 (63lbs min ar.63 oil cooled)
Tial Q 44mm waste gate w/ adapter
420a exhaust manifold ---------------------- SOLD
Trv 185 vertical inter cooler ------------ FOR SALE
Tial Q 50mm bov w/ adapter
3" Down pipe with dump tube
Air filter
Oil line kit, gaskets and hardware
3/13/14
-Brian crower
Intake and exhaust valve guide set
3/20/14
Crank scrapers with baffles
3/30/14
-ebay
Egr block off
3/30/14
-Modern Performance
MPx 60mm Throttle Body. ----------- SOLD
MPx IAC Manual Adjuster -----------SOLD
4/3/14
- www.xtremefabrications.com
Innovate LC-1 Wideband Gauge kit
Aeromotive A1000-6 EFI Fuel Pressure Regulator
Aeromotive Gauge, Fuel Pressure, 0-100 psi, 1 1/2 in
Aeromotive Fitting, Straight, Male -6 AN to Male -6 AN O-Ring 2
Aeromotive Fitting, External Hex Head Port Plug, -6 AN O-Ring 1
South Bend Clutch, non-modular dxd 6 puck clutch
ATI Super Damper Crankshaft Hamonic Balancer - Mitsubishi 420A
Xtreme Fabrications 420A Intake Manifold, 60mm, Polished
ARP Head Stud Kit, 420A
Fel-Pro MLS Headgasket, 420A, HD-0.10
Supertech Dual Valve Spring Kit with Titanium Retainer, 420A
Race-Series Tri-Metal Main & Rod Bearing Set, 420A
Supertech Valve Stem Seal Set
JE Piston & ProSeal Ring Set, 8.5:1 +0.020"
Eagle H-Beam Connecting Rods w/ ARP 2000 3/8" Bolts
MegaSquirt III EMS System - Custom Stand-alone
4/22/14
-www.xtremefabrications.com
XPS "Stage 4" Pro-Street Ported Cylinder Head Service
+ Corrections for 1mm O/S Valves
+ Replace Valve Guides
Port & Polish Intake Manifold Lower Runner Section
Port & Polish Turbocharger Turbine Housing
XPS Short Block Service - Balance & Blueprint
Long Block Conversion Service, Incl. Camshaft Degree
Xtreme Fabrications DSM 420A ProRace Turbo Manifold
Xtreme Fabrications DSM 420A ProRace Wastegate Dump Tube
XPS NV-T350 Stage 3 ProStreet Transaxle Rebuild Service
Quaife Limited Slip Differental
Driveshaft Shop 750HP Level 5 Axle / Hub kit, 2G/NT
Timing Cover - Inner
Timing Cover - outer
Oil pump, High Flow
Water Pump
Fuel Rail Modification, Cut/Weld -6AN fittings, Media Blast, Paint
Thermostat Housing, outer
Thermostat, 180 Degree
Radiator Fan, 12" Slim, Pusher
Aluminum Radiator (convert turbo to non-turbo)
Coolant Overflow Tank, Aluminum, 1 Pint, AN fittings
AN bradied hoses, hose ends, fittings for coolant overflow tank
Oil Catch Can, Aluminum 9est)
Valve Cover Modifications, install AN fittings, media blast, paint
AN braided hoses for oil catch can
MSD DIS-2 Ignition System w/ Dodge coil tower adapters
6/1/14
Gsx powder coated red calipers front and rear
Stainless steel break lines
Master and slave clutch cylinders
Master to slave clutch line black and ss ill decide later which one ill use
Evo X gsr wheels
Stock Front bumper
8/1/14
Crower Stage 3 cams
Custom Front Mount Intercooler
Custom 3" Stainless Steel Exhaust
ARP Cam Tower Stud Set
Custom welded with v band IC piping
(Fuel system)
RC Engineering 1000cc Fuel Injector Set
Holley 255LPH HP Fuel Pump + Install Kit
Accel High Pressure External Fuel Pump
Custom Aluminum Bracket for External Fuel Pump & Filter
Aeromotive In-line Fuel Filter
Rubber Insulated Mounting Clamps for Fuel Filter
3/8 NPT Female Weld Bung 2
3/8 NPT to -6AN Coupling 90 Deg. Adapter 2
-6 Tube Sleeve, Nickle Plated 1
-6AN Tube Nut, Aluminum 1
-5 Tube Sleeve, Nickle Plated 1
-5AN Tube Nut, Aluminum 1
-6AN to -6AN Coupling, Straight, Male 1
-5AN to -6AN Coupling, Straight, Male 1
M10x1.0 to -6AN Adapter, Straight, Male 2
-6AN Hose End, Straight 10
-6AN Hose End, 90 Degree 4
-6AN Stainless Braided AN Hose, 20 ft.
Custom Aluminum Bracket for Fuel Pressure Regulator - Polished
Hardware, Chrome Spacers, Stainless Fasteners
Fuel Pump Rewire Kit
Finally 4/12/14 going to start pulling out the engine and get everything ready to get sent out to www.xtremefabrications.com for the machine work,Wicked excited!
2/25/14
-Cimotorsports:
Arp main stud kit
2/28/14
-Cimotorsports:
3/1/14
3/12/14
-Ci motorsports
-Amazon
3/13/14
Air filter
3/13/14
-Brian crower
3/20/14
3/30/14
-ebay
Egr block off
3/30/14
-Modern Performance
4/3/14
4/22/14
Oil pump, High Flow
Water Pump
6/1/14
Evo X gsr wheels
Stock Front bumper
8/1/14
Crower Stage 3 cams
(Fuel system)
