toppertopper
- 444
- May 14, 2009
edmonton,
AB_Canada
Brother picked this up 2 years ago ,1994 eagle talon fwd, fresh rebuild (had no proof) fmic , 3' exhaust , maft and maf , with bov, 16g,kyb gtr2 suspension ..Wouldn't go into gear $600 no body damage $300 for tow 3 hours away
Pulled the trans off found out the act clutch spring fell out and master was leaking (found out it had a n/t transmission)
Brother has me put in an center force dual friction clutch in, along with a master and slave ..Well that lasted 100kms , thats when the drivers fender got kicked a bunch of times ...Thats when i was given the car
I then installed and act 2600 clutch , shortly after the break in ...I dumped the clutch for a launch ... no more clutch limped it home at 5km's
After that i ordered and act 6 puck unsprung race disk , paired that with the act 2600 pp and it held up
Finally i decided it was time to start building a talon for the track and stop playing on the streets ,
Bought:
Wideband , dsmlink , rc 750 cc injectors , walbro 255 fuel pump
Had a problem with starting..changed spark plugs,wires, relays ,fuses , went thru lots of shiiit , not sure how or what fixed it...
Next up , stretched water pump bolts , and blew the head-gasket ..Ripped the head off got new pump and bolts , new timing components , ahh the fun .I did find out it was a fresh rebuild , oil port mod , port and polish ..Not sure of the bottom end stuff yet
Installed the wideband , dsmlink , rc 750 cc injectors , 255 fuel pump with rewire mod
Had a local dsm'er come do a basic car running tune (BIG THANKS TO DANNY ) (someone stole my house phone dialed 911 and tossed it in a bush,Cops show up had to make sure all was good, HOLY SHIT 1st time meeting the guy to )
Next up , noise coming from trans tob sound ..Pull the trans off toss in a oem tob (THANKS TO G-FORCE), after i put it in i toss on new ball joints and cv joints .
Last day for street legals was coming up fast and G-FORCE stayed on me to finish , tossed it together still the same noise ...Was not going to go,the never been to a track jitters ..But G-FORCE txted me to go , finally got off my ass ripped out to the track ..Bald front tires (will get pics)
Note: Once i got the car i put maybe 500-750 km's on it , tossed lots of money into fixing everything ...The things we do for these babys
All runs were on 7-10 psi no more -4500 RPM rev limiter , bald front tires
1st run got excited spun to 3rd for a 16 sec pass
2nd run spun to 3rd for 14 sec pass (still excited feeling the rush )
3rd run 14.3
was going to leave , let the car cool down for close to an hour with fans on decided to do 2 more runs , run or blow was my thoughts , last run of the year!!
4th run was 13.5's .. Stayed calm eased into the launch
5th run 13.1 ...I told my self 2 runs no more,.. i left after i let it cool down
Started ripping out the interior back to front , will be finishing this before spring.
Winter time came , and i came across a hx35 picked it up and decided to upgrade all over winter
Bought
valve cover and new valve cover gasket hx35 , rc 1600 cc injectors ,Turbonetics T3 Cast Exhaust Manifold (real not the ebay knock offs) ---Pics of all will come soon
Next to buy
innovative lc-2 , 38mm TiAL F38 wastegate. , new mbc , afpr ,qtp slicks , and get an 02 housing fabbed to exhaust
Bought:
3rd run 14.3
Bought
Next to buy
