| Welcome to DSMtuners |
| DSM Build Journals: Start a Journal to document your DSM build or document a race event you participated in. |
06-12-2012, 06:52 AM
Show Printable Version
Email this Post
#31 (permalink)
Supporting Freelancer
Syn Customs
Car: avenger 2.4 swap:boosted
TSI: I was about to rip in lol.. but I can apprciate the fact that your willing to give credit when its due : ) its apprciated. Its nice when ppl can step back and recognize the work.
Cabo,. can you post the cam sheet for these"crower 272/272 stage 3 cams " as im 99.999 sure that crower, or any cam company doesnt make that cam profile for our platform, and i know your not using 46gX cams in there (its not possible).. just curious to what you actually have. The number is also etched into the cam, there the cam magnet gets installed, so you can pop it off and grab the numbers. You have a lope, so im guessing you mean Crower Stg 3? (those are no where close to 272/272 for the 4g6x in terms of cam profile.)
and what tb are you unning? a 5MM? lol, did you mean 50mm? At any rate its a stock housing, im guessing is bored to 55 MM. a 60 Mm would do you well, as well as porting the IM to match.
Im a little surprised your running the 420a computer still. did you swap the firining order? and rotate the Cam magnet? Just wondering b.c you mention its not fast.. it should be noticibly quicker (without boost), due to the higher torque. that and im not sure how far running the 420a computers goiing to get you , as those fuel trims are for the 2.0, so its like your starvin it for fuel.
.25 is to small .35/.32 is typical for us.
whats your afr at WB?
Holy balls , i watched that vid.. IMO:
1. Your turbos to big.. no wonder your not moving, your boost barely kicks in when your in the sweet spot.. Imo, the 2.4 repsonds well to a 5857- thru 6262. so a gt35 r would been good for you, still a little laggy, but i think urs is way over kill.. whats your gaol? do you have any trans mods to support needing that power? same goes witht he 3" piping.. ## making the turbo work harder to fill all that volume.. bigger isnt always better.
2. Do you have bal shafts removed? Either way your taking that 2.4 up a lil high.. these things dont like rpms above the 7K ish range. Hopefully you dont have balance shapfs, and you have some sort of oil control in your pan and in your head (a .120- or .130 restictor).
3. I see something by the Fuse box, Why the dual oil filter?
What pan are you running?
4. Your still running EGR.. : (
5. stock valves and springs? after stg 2 cams, those really should be upgraded.. heps rduce valve float.
6. you mention port and polish, any pics? just wondering how much is polished and to what extent, Polishing (common mistake) really isnt a good thing, it doesnt creat turbulance to deliver fuel correctly, adversly effects atomization etc..
____________________________
Custom fiberglass and carbon fiber fabrication - click on my Supporting Freelancer icon to see what I offer!
06-12-2012, 11:01 AM
Email this Post
#32 (permalink)
Car: 96 gs edz swap boosted
Glowryder: I meant to write 57mm tb but i missed a key. I like the egr for the mpg as this car is still a daily griver my girl uses to get to and from school. I am only running 6 psi through it and the turbo actually spools perfectly in time for the cams to start making alot of power. I guess my impression of fast is tainted because i play with so many fast cars but as a non turbo edz it was able to take on a fox body mustang but not much faster than that. Now that its running 6psi I managed to pretty badly beat a sc ford lightning yesterday from a stop. the cams are crower stage 3 with 272 (what the ad said when i bought them used) i do remember them saying crower. here is a pic of one compared to stock cam
Facebook
i used a stock oil pan cut and modded with homemade windage tray and removed balancer and re arranged the coil and injector wires also ground the pegs off the magnet and rotated it 90 degrees. dual oil filters came along because i wanted more oil capacity. I also have a condensor sized oil cooler in front of the radiator now. total of 6.5 qt oil capacity. all im gonna do from here out to that car is put 440cc injectors in it and raise the boost to 8psi. after that no more mods its fast enough for my 22 year old gf! my supra is the next toy im gonna make fast.
06-12-2012, 11:17 AM
Email this Post
#33 (permalink)
Syn Customs
kool sounds good! as for the cams, if you get board, id grab the PN and cross it on crowers site. I bet they are st3's, no doubts, esp with the idle lope, but they dont have the 272 profile. If you cross the numbers etched on your cam to the site, they will have ## specs. keep up the good work.
06-12-2012, 11:34 AM
Email this Post
#34 (permalink)
Thanks i think i might look up the cams now because im curious.
new pix of the edz swap are uploaded now. only 2 though because this site is a pain in the azz
Reason: Auto-merged with previous post to prevent "bumping" within a 24 hour period
Tips on avoiding the auto-merge feature - http://www.dsmtuners.com/forums/faq.php?faq=vb_faq#faq_bumping
07-26-2012, 08:31 AM
Email this Post
#36 (permalink)
Syn Customs
?? You cant do this to a 420a.. its a full swap. : )
Trans and Head are bout the only stuff you can slavage from the 420a to swap in a 2.4
07-26-2012, 04:02 PM
Email this Post
#37 (permalink)
Parts list:
Custom passenger side engine mount
custom made injector harness with at least 260cc injectors (if ya wanna gain power without tuning)
complete 96-02 dodge stratus 2.4 bottom end (stock internals will work unless your looking for more than 300hp)
2.4l headbolts (srt4 arp will work i believe)
2.4l timing belt for the year tensioner setup your using
2.4l top idler pulley
modified cam sensor magnet (rotate clockwise 90)
mls gasket (2.0l and 2.4l are the same)
and the hardest part is the oil pan... you can use the stock stratus pan from 96-98 stratus (one layer steel) and modify it or you can run the exhaust out the side of your front bumper lol. Not many people know how hard this swap really is besides Glowryder and I. oh and by the way no the srt4 engine is NOT compatible so get that outta your head too.
Cobo's Customs 96 eclipse 2.4 edz swap 92 trim
07-26-2012, 05:28 PM
Email this Post
#38 (permalink)
Syn Customs
Your stock injector harness is fine.. no need for a custom ine.
Srt head studs are what you want
All srt timing componets and oil pump is what you want. You also want a srt water pump. Yes there is a differnce between those and pt cruiser/stratus.
Swap in srt internals.. i wouldnt trust stock over 8psi..srt internals are cheap and good for an easy 400hp.
Send your oil pan to IJ once its modified for a crank scraper.. you will want one.. you also should remove bal shafts and plug th bal shaft oil imput. You may need to do a remote oil filter depending on the pan you make. You should go msns for engine management. Theres really no other reason to swap and not fully build the crap outa it.. thus the ms comment.
07-26-2012, 05:29 PM
Email this Post
#39 (permalink)
Syn Customs
07-26-2012, 07:44 PM
Email this Post
#40 (permalink)
I would have to agree allthough his is a little overbuilt and mine is a little underbuilt I am at 8psi on stock internals (stratus) and its an amazing ride!
07-27-2012, 05:53 AM
Email this Post
#41 (permalink)
Syn Customs
overbuilt? Im Plan to cram 25 Psi down it..That calls for a certain level of build.. I guess im not an average DSM'r, I dont just throw ebay crap together lol. cheers
07-27-2012, 01:46 PM
Email this Post
#42 (permalink)
hey hey hey be nice man I was not being mean I was feeding a compliment. believe me I would build it just like you did if I was not always so broke! I guess I use the word overbuilt to make myself feel better
07-30-2012, 08:08 AM
Email this Post
#44 (permalink)
Syn Customs
Its all good. Our shop prides ourselves on it  I guess we dont think there is any such thing as over built, just better insurance  cheers
08-06-2012, 07:42 PM
Email this Post
#45 (permalink)
Syn Customs
08-07-2012, 05:50 AM
Email this Post
#47 (permalink)
Syn Customs
IDK yet. perhaps if i can make my way there lol
08-07-2012, 09:20 AM
Email this Post
#48 (permalink)
Proven Member
Got a log of that with the ignition values?
415whp 365wtq on 2.0L
Journal: Project Alice
08-07-2012, 12:03 PM
Email this Post
#49 (permalink)
Syn Customs
i can switch some of the tables and get a snap shot , ill try to post it tonight.Eric didnt push the envelope, but they are set to a little agressive/ what has worked in the past with this cam profile.
08-20-2012, 09:42 AM
Email this Post
#51 (permalink)
just finished a rebuild on my edz using the stock srt4 pistons and rods with clevite bearings and a .025 reground crank. seems a little more fuel hungry under boost with the lower compression but overall I think its gonna be a real dependable setup and i would rec. this setup to anybody for a budget build
08-20-2012, 10:04 AM
Email this Post
#52 (permalink)
Syn Customs
Budget swaps are for Honduhs : p. Yea the 8.0 CR your running now will be More fuel hungry b.c its mking the motor work more, your loosing turbo Efficency , but thats a "production" car for ya. Ouch on the crank Journals, I wouldnt push more then 300 ish with that.. What are the Tollerances you used for the Clevites? Did you use the HX, H or P series? That will also limit you depending on what you used and Toleranced. I guess i shouldnt say Limit, more of , define Freqency between rebuilds : )
08-20-2012, 08:51 PM
Email this Post
#53 (permalink)
Syn Customs
08-21-2012, 08:15 AM
Email this Post
#55 (permalink)
Syn Customs
As long as theres no rain anywhere near : )
08-29-2012, 10:59 AM
Email this Post
#56 (permalink)
yeah yeah yeah not the super cool xxxxx$ build glowryder is able to pull off but its a great running beast. mains are at .002x rods are at .0015 ptw was .030 give or take a lil. ring gap was .020 top and bottom. I dont care if anybody else would have done this build different it is only ever gonna see 12psi on 440cc injectors. its on a stock 2.0 n/a ecu and doesnt even throw a code unless it sits at its lopey idle too long (p0300) so I must have done something right.
08-29-2012, 11:10 AM
Email this Post
#57 (permalink)
Proven Member
My boosted 420a is slow at 10 psi with 450s and a sfmu...I musta done something wrong. Best time was a 16.1 when i should be in the 14s!
08-29-2012, 12:28 PM
Email this Post
#58 (permalink)
Quote:
what was your reaction time and 60ft? how good is the power getting to the ground? whats your afr under full boost? why are you only running 10 psi at the track? oh and by the way this thread is about the edz not the 420a so text me or send a message
08-29-2012, 12:52 PM
Email this Post
#59 (permalink)
Syn Customs
agreed, you should be in the 14s.. even a poor reaction will not cause that slow of a time. My guess is your super rich. What are you even tuning with? I know you were going to go MS. Hes ###### running 10 b.c of the SFMU...
08-30-2012, 07:24 AM
Email this Post
#60 (permalink)
Proven Member
Im tuning it with the sfmu only thing i really can right now. only at 10 because of the stock clutch and my af ratios in boost are like 10.5 i want a 11.5. Cobo ill txt ya in a little.
» Recent DSM Videos |
» Online Users: 610 |
| 216 members and 394 guests |
| Most users ever online was 1,704, 03-17-2008 at 09:11 PM. |
