| Welcome to DSMtuners |
| DSM Build Journals: Start a Journal to document your DSM build or document a race event you participated in. |
05-30-2012, 07:52 PM
Show Printable Version
Email this Post
#121 (permalink)
Supporting Member
Spun bearing carnage..
Hey guys, last week I was positive I spun a bearing in the car. Well yesterday I was able to actually inspect the bearing. Yup sure did. Pretty damn bad too. The video was right before I started tearing the motor out.. Pics are just from yesterday..
Car is back up and running on the stock short block with all other mods.
As I took the rod cap off
Rod cap
bearings
Crank journal
____________________________
Tom
05-31-2012, 12:31 AM
Email this Post
#123 (permalink)
Proven Member
Ok, not trying to be a douche here.. This is a real honest question, why do so many of these engines get rebuilt only to spin bearings within 1k of driving? Did you do something wrong?
05-31-2012, 05:54 AM
Email this Post
#124 (permalink)
Proven Member
NO!        , and some more,
O.k., got that out of my way and yelled outside, I haven't checked up on this and you in awhile, so I feel super bad that this happened! Anyway, Good luck on the rebuild once again & have a quick & easy recovery.
To the post above, many rebuilds fail on the first 5k or less for only very few reasons, "Clearance", "Specs", and obvious little things. If you do not check, double check, and check some more, than it will happen to you period.
05-31-2012, 08:08 AM
Email this Post
#125 (permalink)
Supporting Member
Quote:
I really dont have a direct answer to that pertaining to my situation. It could have been a number of thing. Although I did take as many precautions to keep everything clean as hell (best I could, I mean Im not working in a damn bubble) clearances were spot on as per the maintenance manuals along with the 4g63 specific book I bought.
Now, the only thing I can think of would be that I did use a used crank. Perhaps that journal was worn or not round. Hell it could have been perfect and I somehow got some contamination in it during the build.. IDK..
Im one to learn from my mistakes. This is a lesson learned.. I wanted to build the motor myself. If it worked awesome, if not, well then I needed something to improve on. Now I have to get a new crank, bearings and another Eagle rod.. Oh well shit happens.. This is why I kept my spare motor intact.
Tom
05-31-2012, 05:41 PM
Email this Post
#126 (permalink)
Proven Member
Are you still on WG pressure or have you turned up the boost at all? Sorry to hear about your motor.
05-31-2012, 06:06 PM
Email this Post
#127 (permalink)
Supporting Member
Right as I spun the bearing myself and Mr Peepers were dialing it in.. We got up to 23psi. Still a bunch left, even on pump gas. Then even more when I make the switch to E85.
Tom
05-31-2012, 06:52 PM
Email this Post
#128 (permalink)
Proven Member
Quote:
Do you remember what RPM you were seeing 23psi at?
05-31-2012, 06:57 PM
Email this Post
#129 (permalink)
Supporting Member
Just checked the log and I saw full boost at 4400 RPM in 3rd gear.
Tom
05-31-2012, 08:17 PM
Email this Post
#130 (permalink)
Proven Member
That's nice. It looks like the divided manifold is spooling up the HX35 about 1,000 rpms sooner than an undivided manifold and still has the benefit of all the top end.
Looking forward to more updates.
06-18-2012, 08:10 AM
Email this Post
#132 (permalink)
Supporting Member
Quote:
Originally Posted by 96' Eclipse GS
Any updates/progress on the build?
Nothing really. I pulled my built bottom end and threw my stock shortblock back in so I could have it running.. Been up and running for a couple weeks but havent had time to get to dial it in again.. Hoping we can this weak.. hoping to see around 27 psi, "should" net me mid 400s.. This is all still on pump 93 oct.
Tom
06-18-2012, 08:17 PM
Email this Post
#133 (permalink)
Proven Member
Good to hear that you are working on, and have not given up with no hope. Let's us know what is going on!
06-20-2012, 08:14 AM
Email this Post
#134 (permalink)
Supporting Member
Car: 1997 Talon TSi Spyder
Damn, didn't realize how bad you spun the bearing when you mentioned it on my posts. Sure hope I don't get the same result from mine. Your engine was too awesome to have to go through that, sorry bro.
-Dag
'97 Talon TSi Spyder (AWD coming soon)
07-16-2012, 02:39 PM
Email this Post
#135 (permalink)
Proven Member
Clean car, sucks your engine spun a bearing. At least you got it running again.
92 TSI,95 GSX,97 TSI,99 GSX,02 WS6,09 SSlowbalt
07-31-2012, 08:54 AM
Email this Post
#136 (permalink)
Supporting Member
Hey fellas, I suppose I could give a little update of whats been going on.. For the last couple three weeks or so Ive been hearing a strange tapping/squeak Ive never heard before.. Coming from the timing side of the motor so I looked around a bit. Seemed to sound like it was coming from perhaps the idler pulley for the timing belt..
It started off sounding like a piece of plastic was tapping against a body panel or something similar.. Then progressively got louder and more consistant.. One day it was just too loud, I had to figure out what the problem was, only "big" problem was I was about 25 miles from home.. Heres a vid of that day.
Dsm noise from timing side - YouTube
Started to sound like a belt squeaking but not quite.. Looked down at the harmonic balancer from the top and noticed it was wobbling a bit.. Ok its just loose, nope sure was tight.. THen saw this!!
Picked up two other ones from a local just havent had the ambition to put it on yet!!
Tom
10-11-2012, 12:08 PM
Email this Post
#137 (permalink)
Coilovers on your Spyder
I am new to suspension on a spyder. I have a 1998 2.4l Spyder GS and want to purchase coilovers for it. what brand coilovers do you have on your Spyder? and do you know if they would fit on a GS spyder or is suspension different? Any help would be awesome. Nice build BTW!!!
10-13-2012, 10:32 AM
Email this Post
#138 (permalink)
Supporting Member
Update
Hey fellas, wanted to give a small update. This whole season I was seeing a bunch of knock while trying to tune so the car wasnt being boosted much at all. REcently I started over with my tune and got things figured out. Happy to say Ive got the holset up to 25 psi on pump 93 oct. Feels like a monster. Flowing 48 lb/min by 7k rpm. I was supposed to go to the track this past friday but ended up getting rained out. Next week I will though and will update!!
Dsmracer: I have Megan Racing EZstreet coilovers. Im not very sure if the suspension components are the same. Youd have to get ahold of a vender and ask them.
Tom
10-14-2012, 02:35 AM
Email this Post
#139 (permalink)
Proven Member
Wow man the build is incredible!! I'm looking to start my build soon as well snapped my timing belt f'd up a lot of crap, your looks great tho, wish I was around you would love to have taken part of the build being as I have a spyder as well.
10-14-2012, 05:49 AM
Email this Post
#140 (permalink)
Proven Member
Very nice build man, I don't think I have ever come across it until now. I have a soft spot for spyders  It sucks to see your built motor go so soon, that's one of the reasons I have stuck with stock block so far (and money of course...). Have you got spool any lower with the new tune on there? 4400rpm for 23psi seems really high for the twin scroll, I thought the holset threads were saying 20psi by 3500rpms easily?
Hi. I'm Caleb
10-14-2012, 08:27 AM
Email this Post
#141 (permalink)
Supporting Member
Thanks for the comments guys!
Caleb, unfortunately I havent figured my spool "issue" out quite yet. 4400 rpm does seem a bit high to me too. Ive read and heard that BC cams do need to be degree'd to actually be right. Thats one thing I havent tried, but I want to. Im betting if I degree the exhaust cam a bit I could pick up a little bit of spool.
Tom
11-29-2012, 06:17 PM
Email this Post
#142 (permalink)
Supporting Member
2012-2013 Winter upgrades
Well hey there again guys! It about time I get the Spyder back into the garage and tear into her again.. This year wont be near as intense as last years was but still should keep me pretty busy for a few weeks!! The engine is coming back out so I can clean the bay back up since I had a few oil leaks with this old block and my alternator belt was rubbing on the timing cover so theres a bunch of black junk all over the timing side of the bay. I also have a CV boot that keeps ripping
Plans:
* Track down power drain that kills my battery in around 5 hours
* Pull motor and clean bay
* New clutch, going with an ACT2600. Buddy of mine has one that Im picking up. My 2200 equivalent South Bend apparently doesnt like 26 psi on the holset.
* Fix oil leaks and redo turbo oil drain
* Put a Vband clamp off the turbine side to my exhaust (I fight and fight to get my flange to line up with the hotside)
* Fix cv boot and make a guard to keep future breaks from splattering grease all over
* If I feel up to it I might find another engine wire harness and redo my wire tuck
* Rewire my 255 pump and drill out the return relief hole; E85 next se
* Run lines and set up my new boost controller
* Full 2gb Talon conversion!
Im sure there will be more I do and think of while I have the car apart, this is just what I can think of that I really need to get done this year.
Here are a couple pics /J took a couple weeks back. We decided to take some pics and it was sunny. Finally get out there and it was cloudy and started sprinkling. We only had about 5 minutes of sun to play with!!
Tom
11-29-2012, 09:23 PM
Email this Post
#144 (permalink)
Supporting Member
As much as I like it as it is now, there are TWO other white gst spyders in my area.. And one has the 2gb wing on it. I dont want anyone around here having something that looks like mine! I want one of a kind, something unique that is part of my personality! And I absolutely LOVE 2gb talons and believe they definitely should have made a Talon spyder!
Tom
12-01-2012, 09:42 PM
Email this Post
#146 (permalink)
Supporting Member
Heres as far as Ive made it so far!! haha.. Lately been kind of doing some maintenance on my 1g to get it ready for the snow, if we ever get any.
Tom
12-03-2012, 08:23 PM
Email this Post
#147 (permalink)
A 2gb Talon Spyder would be badass! Do it! If you need any pieces for the conversion let me know. Good luck with it Tom.
12-03-2012, 11:09 PM
Email this Post
#148 (permalink)
Supporting Member
^^ I do, haha I need everything! Front and rear bumpers, tail lights and the side slash trim pieces..
UPDATE *ISH: Today I finally started taking the car apart.. Did probably an hour and a halfs worth of work in about 3 hours. Got everything ready to pull the motor besides the axles. Just couldnt get the motivation today. Thank god I dont have a shit load to do this year and plenty of time to do it!!
Tom
12-03-2012, 11:36 PM
Email this Post
#149 (permalink)
The junkyard in sturtevant has the pieces you need like snohacking said. Give em a call. They're normally pretty good on price.
12-04-2012, 10:35 AM
Email this Post
#150 (permalink)
I love your build man! It has been inspirational for my spyder build! but did i read that right that you are getting rid of those beautiful side skirts that you have on the car? if so dibs! lol but really I have enjoyed your build so much!
» Recent DSM Videos |
» Online Users: 1,035 |
| 398 members and 637 guests |
| Most users ever online was 1,704, 03-17-2008 at 09:11 PM. |
