Could this be crankwalk!
eclipsegst24
Sep 12, 2003
The other day i was driving along everything was fine till i took a left turn and my clutch pedal stuck the the floor, i couldnt shift into any gear. I checked the fluid and it was empty, i filled it then tried to pump the pedal and nothing, then i bleed the fluid and filled again, still nothing. You can push the pedal down with no problem but i had to pull it up with my hand to get it to go back up. I did notice there was fluid down by the pedal on the floor. Someone told me this is my master or slave cylinder that went out. Is this true or is it something worse.
Sounds like a Master Cylinder Failure. Rebuild/replace and it should be fine.
