Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 08-14-2002, 04:26 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: kidd gs-t is an unknown
update on tranni problem, i have foudn the problem !!
hey, i finally figured the problem, i called keith from BMtranny for some help, (real nice guy, i recommend his buisness everytime for tranni problems!!) and he pointed it out, it is the slave cylnder! It was already in bad condition probably, but he pointed out that since a stronger clutch was installed it probably made it worse and caused a leak! I problem now, how do i replace that? i have never encountered this problem b4, where is it located, i'm also planning on removing the restrictor also while i'm at it, ne advice apreciated!!!
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09591889 seconds (61.90% PHP - 38.10% MySQL) with 9 queries
